Reshaping objects
Tool
Tool set
Reshape
Basic
The Reshape tool reshapes an existing object by moving, removing, changing, or adding to its vertices. Change the length of objects (including dimensions), reshape single objects, or reshape multiple objects at once. Reshape polygons and polylines, including lines drawn with the Freehand tool (which are considered polylines). In addition, specify exact radius measurements for circular arc control points. The Reshape tool can also be used to reshape 3D solids, roofs, stairs, NURBS curves and surfaces, and other objects.
The modes and functionality available for the Reshape tool depend on the currently selected object or objects, and the current view.
Functionality enabled
Selection or view
2D reshape
2D planar or screen object, in any view
Multiple objects selected, in any view, or a reshape marquee exists
Wall, roof object, stair, site modifier, plug-in object in Top/Plan view
3D reshape
Single 3D polygon, 3D solid, NURBS curve, NURBS surface, section line (Vectorworks Design Suite product required), in any view
Roof object, stair, plug-in object with custom reshape behavior (such as the retaining wall site modifier, Vectorworks Design Suite product required), in a 3D view
Marquee
No selection
2D reshape modes
3D reshape modes
Marquee modes
Performing multiple reshapes
Converting polyline vertices from arc to radius
Reshaping roof objects
Reshaping stairs
Reshaping the modifier path or boundary
